- May 29, 2018
- 4.0L
- Manual
- Total Lift
- Crap load
- Tire Size
- 35X12.5 (bald so I don't break parts)
- My credo
- Low range in Nova Scotia on YouTube!
I'm laying in bed and I'm thinking.....I don't like that front skid plate...it looks unfinished....maybe tomorrow I'll add wings or something to fill it in or "finish it off"
So;
Then I decided to start the light bar. I need a relay..I wonder how bad that fuel pump relay is, why buy new when you can fix old right??
I pulled the top off the relay and the points were burnt like I thought. So I grabbed a points file (it's for filing the points in an older vehicle for you young 'uns lol)
Anyway, filed the points and tested it and voila! it worked. 12v in and out on the large leads (the small leads run the coil) wired a light to it and it flows amperage as well, all good!
Next was the light bar, I was concerned that with my height restriction (to get into the back of the toy hauler) I couldn't go above the roof. So I decided to grab a couple of old hasps I had laying around and make a "drop down" type of mount. Then I could drop it down for transporting and then raise it up and bolt it solid to wheel. Take the bolt out and the bottom part hinges down (with the light) and the top part is welded solid to the cage.
I was concerned with the wires getting caught and ripped off as I drive a lot in the woods with very tight clearances. So, I used brake tubing to make an armoured wire protector. Now the wires can't get ripped off!
Wow, that was a crappy picture...anyway, you can see the tubing hose clamped to the cage and entering between the hood and the firewall. (I thought I would have to cut/fit it but the truck was tweaked quite well in the accident and the tubing slide right in. LOL!!)
And here's a picture from the front. I tried with the light on, holy crap is it bright!
Oh yeah, I did some hacking and slashing and got the headlights bolted in and hooked up too. Now I have high/low beam plus blinker/4 ways for driving on the side of the road. I have to put tail lights on next as well as a box/flatbed/something. For now though, I gotta get it out of here as my kid is coming home from his helicopter course in another province which means I won't be allowed at work. (must self isolate at home)
So the next pictures will be from my own garage at home. (once I decide what I'm doing next...)
So;
