The Bruiser
Well if I decided to do the solid axle that creates the problem of finding one which are slim to non were I live
so I cant find a hp d44 to save my life found a d44 that wasn't and a d60 the guy only wanted 350 for all but that's not the d44 Im looking for so Im back to the d35 swap for now tell a d44 appears.
on the bright side I return home in a couple weeks from the stan. so the build will start an pictures well be uploaded
350 is a good deal for matched axles,why not do a low pinion front now,and if uou find a hp in the future its an easy swap
Sent from my DROIDX using Tapatalk 2
Is it that easy to swap out I was thinking it had to set up differently do to the pinion that being said im a beginner an have never swap axles or new anything about it tell I joined the ranger station
Once it's set up for a solid axel you can modify the new axel to fit fairly easy. If you're getting a hd-44 I believe you would be able to find a new housing and swap all your internals and knuckles over and keep the 8 lug pattern. 3/4 ton ranger FTW!
Is it hard to shorten the axles
I haven't done it yet but I've researched it. It seems pretty easy as long as you have a angle finder. There are several videos on YouTube showing how to do it.
Looks like ill haveto get a angle finder I dont have one
Got my angle finder still looking for a d44 anyone got one for sale.
On the plus not finaly made it back to the states in a few days ill be home tearing into this truck
Found a d44 high pinion an 9 inch rear for my ranger its a full width axle oh well anyways it came with the entire front end even the steering box got it all for 275 does need redone though
Pulling the motor tranny an transfercase
The Bruiser
All out
The Bruiser
Empty
The Bruiser
Taking the body off
First the bed
The Bruiser
The Bruiser
Then the cab
The Bruiser
The Bruiser
Theirs a lot of rust on the cab mainly on the fire wall
The Bruiser
The Bruiser
The Bruiser
Just means I get to put my welding to the test now
Thats alot to do all at once! keep us updated!
Well do been doing some body work an i can place the axles tell my c-bushings comes in its been 2 weeks I'm tired of waiting
