The all-new 2019 Ford Ranger can carry serious gear
Limited slip uses a clutch pack or mechanical system to restrict (but not prevent) one wheel from turning faster than the opposite wheel on the same axle.
A locker mechanically binds them together so that they -must- turn at the same speed. If one is one ice or hanging over a ditch, the other can still pull the vehicle forward.
I thought a positrac rear end turned both wheels in the same direction at the same time. and limited slip turned the wheel with more traction.
See above
OK so a quick search on the web taught me a little. I now know the difference in a positrac and limited slip and a locker. But still wonder if Is it like the old 4x4 where you had to get out and LOCK the hubs manually for the front wheels to turn under 4wd. So now the 2wd rear end can LOCK like that? but from what I understand it is now electronic and computerized. how could the rearend locker be manually locked, hydraulic or cable actuated?
Posi is a GM name for limited slip. Ford used Trac-Lok. Both accomplish about the same thing using clutches. Some vehicles like the FX4 Level II Ranger used gear typle limited slips that didn't have clutches.
The wheels that slip to wheels that grip stuff is done by a computer using the brakes. When the brake is applied to a spinning wheel power is applied to the other wheel on that axle that isnt slipping.
All you do when you lock in the front hubs is tie the front wheels to the shafts that make the wheels turn. Most newer trucks have this operated by vacuum so you don't have to get out to manually lock them in.
Locking hubs have nothing to do with locking differentials.
This might help:
https://auto.howstuffworks.com/four-wheel-drive.htm
Great read. Thnx 85_Ranger4x4. this answered a lot of my dumb questions. sorry to bog down the thread.
So, IOW, you just take some youtubers word ?
Did you watch the video ? It doesn't take an engineer or a genius to see the inherent weakness of the 2.3EB cylinder design. When compared to an LS-1 or WRX-STi block, it becomes quite obvious to the observant....watch the video :icon_thumby:
So how do they stay together in everything but a Focus RS which has several headgasket related difference compared to every other application?
And isn't the 3.5 Ecoobost the same open sleeve design?
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2142065&page=all
I didn't realize the 3.5 had the same block design...interesting... Maybe 3 floating cylinders are stronger than 4. The idea of an area of such high stress just hanging there, with no connection to the head (pins or bolts), doesn't sound like a good idea. :dntknw: I also read the Ford GT uses the same 3.5 block as the F-150, and I haven't heard of any issues with those either, but I'm sure they aren't driven much.
I may be starting to see the light. It would be nice if they did add some type of support to the upper end of the block around the cylinder :icon_thumby:
One reason for went to aluminum bodies on their full-sizes. One truck that weighs a thousand pounds more than another can pull a thousand pounds less.
Ford switching to aluminum bodies had absolutely nothing to do with towing capacities. Ford is simply getting their technology straightened out ahead of time, to adhere to future fuel efficiency standards set by the federal government.
Any increase in towing capacity is simply coincidental.
GB :)
It is the 2.3 EB. If you search youtube for "Focus RS engine failure", there are literally dozens and those are only the ones that made vids and uploaded them.... If you go to 5:15 in the video, he explains the head gasket issue and why it failed and why the block design is flawed. Until they redesign the block, so the cylinders aren't floating, I won't buy one.
https://www.youtube.com/watch?v=Nan3LURIq3k
Interesting video and counter point. I wonder if it's and issue with the amount of boost with the Focus? I don't know what the Mustang hp level is but the Explorer is less (285 hp vs 310hp - drawing from memory). I know engines not designed to be turbo boosted have head gasket problems if boosted so much. Perhaps an apples to apples comparison here?? I'm not an engineer, so just a basic auto mechanic and aircraft mechanic thinking here and might be off base.
Just a thought. If the motor is your car'so
heart, wouldn't you want a big strong heart that doesn't have to work too hard to get you going, or a little bitty heart with an added device forcing it to do the work of a bigger heart?
lol what could you haul with that pathetic 5 ft bed? whatever happened to a single cab with a long bed?
OK so a quick search on the web taught me a little. I now know the difference in a positrac( or spooled, I have seen the spider gears welded together for the same effect, I think ) and limited slip and a locker. Just like the old 4x4s where you had to get out and LOCK the hubs manually for the front wheels to turn under 4wd. So now the 2wd rear end can LOCK like that? but from what I understand it is now electronic and computerized. how could the rearend locker be manually locked, hydraulic or cable actuated?
And why would you want a non-locking ( open ) rear end in a truck? so it looks like a motorcycle did a burnout when it was really a Ranger. lol
Positrac is just one manufacturer's name for a limited slip type differential.
Ford GT isn't driven much ? They are in just about every race I see televised.
BINGO !!!!! My thoughts exactly. Well said sir (or ma'am)
I am betting they need all the coolant contact they can get to keep them cool. Support legs or pins would create hot spots
It sounds like the focus blocks were not made correctly, he says as much in your video saying that they are warped without being overheated. It doesn’t matter how you make a block, if it is warped you are going to have head gasket problems.
The 2.7’s had oil consumption problems for awhile because their blocks (and valve guides in a separate issue) were not made correctly too.
GB :)
Uh huh. Superduties that are not measured too?
I said one reason, not the only reason
We were discussing the F150's.
I have been talking about the F150 Raptor not the F22 Raptor.
I have been saying Raptor all along that the FX4 Ranger is getting the same system as the Raptor.
