terrible vibration help
ndube82
I am writing to you all here in hopes of a suggestion or tip that might solve my issue.
Few weeks ago a terrible vibration began in my rear end, now the whole truck is shaking. I had my tires balanced, rebuilt my rear end. Checked the driveshaft u joints, all are good. Vibration is still there, and not getting any better.
Found bad pinion bearing in the rear. This truck is a 4WD but in 2WD mode, so if im wrong correct me , but the front diff and axles are not being used and cannot be a cause of this. Ring and pinion in the rear are meshed well, and tight.
I just picked the truck up from the shop after having the tires balanced, and i can't notice any big difference in the vibration.
On the highway from 50mph to 75 mph, the vibration is so bad the stick shift and transfer case shifter vibrate to the point where they make a loud noise. Feels like the truck is going to fall apart.
Could this possibly be a tranny / engine/ transfer case mount? I'm stumped and driving slow lol.
Please help! Oh yeah, it's a 95 Ranger XL 4x4, short bed.
Almost sounds like a tread separation in one of the rear tires. Maybe take them back to the balancing shop and have them check and see? Have them put them on the spin balancer, rotate the tire, and look for a "bubble" in the tread. Tires with a tread separation WILL eventually balance on the machine but won't show any problems until they are driven on. DAMHIK...
