Louatlvc
- Jan 28, 2016
I'm posting on this thread bc I use my truck daily and can't drive it due to following:
I have 1995 3.0 V6 standard. Just purchased Glow Shift water temperature guage and took day off today to install. Installation involves cutting radiator hose and inserting a spacer that holds an electronic temperature sensor that gets wired to the guage. The idea is that as the coolant heats up it activates the sensor which protrudes into radiator hose and gives reading. After installation, I turned on the ignition and guage went through cycle where the needle goes all the way up then returns to zero. According to tech people this is correct. The problem is that when running the truck the guage did not rise from zero. I ran truck for 20 minutes and stock guage was at normal running temp mid point.
According to tech people at Glow Shift, the insert and sensor should be placed in the radiator hose that does NOT have the thermostat. On my truck this is the lower hose which is where I installed it. The top hose goes to the thermostat.
According to the tech people the only explanation was a bad sensor. They suggested returning it for a new one.
After thinking about it I decided to remove the sensor from the hose insert and test it. I left everything wired as before but this time placed the sensor in boiling water and it worked fine.
When I removed the sensor I had to drain antifreeze again so until I work this out I can't drive the truck. Any ideas why I got reading in boiling water but not when installed?
Any help would be greatly appreciated! Lou
