Well Allan, I installed the Auto Meter temp sender where the factory one was on the top right side of my intake. It seems to work normally at least for now anyway. As for my oil pressure sender, I installed a ''T'' fitting where the stock one was and put the Auto Meter one on one side and the factory one on the other...reads about 30-35#s...guess thats about normal huh?
Now for the BIG problem...On my way to the Bloomsburg 4 Wheel Jamboree, I kinda had a little glitch...
MY PASSENGER SIDE COIL SPRING BUCKET BROKE...taking out my right side brake line too of course....
It basically tore (aka rusted) at the frame from the front back to where the shock is. My coil is now at a 30 degree angle up against the shock, and my frame is on the axle. I had to U-Haul it home from the show...$67.00 later.
You wouldn't by any chance have any coil spring buckets laying around would you???
James Duff makes replacements for $220 and I could then run dual shocks up front, but, not sure if I want to go that route, even though I might have to.
If I do, I wanted to get longer radius arms too, but they are super expensive...Ideas...Thoughts...
Or, should I just rip everything off my 91 Explorer and swap my D28 for a D35...and do a gear swap? So I could do a rear axle swap and put in a 8.8?
D35 needs ball joints and wheel bearings too...
Oh, I forgot to mention, my exaust rusted off at the rear flange of the cat...any ideas on that???
