temp gauge
shadow88
CLOQUET MN
Is there a fuse for the temp gauge? New sensor and still not working
you replaced the 1 wire sensor and not the 2 wire sensor correct?
ground the 1 wire sensor wire and see if the gauge pegs.
the 2 wire sensor is for the ECU and the 1 wire sensor is for the gauge
and the 1 wire sensor is actually called the sending unit
I replaced the sending unit , I even tried a different gauge cluster , both are doing the same thing, oil and temp not working
