Firestar
- Jun 13, 2015
- Latrobe, California
- My credo
- God first
I have a '94 Ranger, 4.0, 5-speed, 4x4. My problem is hard to explain but i'll try. In the morning, after driving about 3-4 miles the temperature gauge will quickly climb to about the "L" in the word normal on the gauge. Then it will quickly drop down to below the "N", and usually stay there. Occasionally it will climb back up to around the "O", then drop back down again. It doesn't seem to matter what the air temperature is. It usually only does this in the morning, after the truck has sat all night (about 14 hours), hardly ever when i go home from work after it's sat for around 9-10 hours. The air coming out of the heater never gets very warm. The heads and thermostat were replaced about 5000 miles ago, the radiator and hoses shortly thereafter, and the thermostat was replaced a second time a few hundred miles later. Seeing the gauge go that high, even for only a couple of seconds makes me nervous. Any thoughts on the reason for its erratic behavior?
