Teddyzee and Iron Ranger... I need your help
But with the Nissan slave is the master cylinder upgrade necessary?
I think 84_ranger brougnt up the point about using a 164T bellhousing. That's a know problem with a lot of headers including the Tri-y's.
Dave
Honestly I was just thinking of doing some :icon_welder: on the patriots and making them fit with some Magnaflow cats. I was going to do that anyways with the AA headers so why not do it to some headers that cost half as much?
My Tri-Ys fit perfectly.
Any slave cyl you find is going to be 3/4" bore, and your Ranger has a 5/8" bore master cylinder. So it will be just close enough to drive you nuts.
Late '80s Rangers were available with a 7/8" master on some V6 models (4.0, maybe?) and that is what I swapped to.
There are some high dollar angled adapters available now to fit the angled firewall with any master cylinder (Willwood, for example)- check classic Mustang sites if that's your style.
I've seen those and I'm not really willing to pay for them. There is the 3/4" bore master from the 1992 4.oL. That would practically bolt-in from what it looks like.
3/4 bore + 3/4 bore = harmony, correct?
Maybe.The T5 seems to need quite a throw, but hopefully that one works.
You'll need to modify the cast pedal bracket like I did, as '94 and older masters bolt to the firewall, instead of clipping the the pedal bracket like '95+.
Most Ranger master cylinders have a stroke of !", believe the best stroke at the slave is 1.25-1.375" for a T-5 without moving the pivot point. With the same bore at the slave, you'r only going to get the same movement at the slave. Just a matter of math. Go with the biggest bore MC you can.
Dave
Alright, before I order these I need the OK from someone. I don't want to find out when I put them in the truck that they won't fit.
RAYBESTOS Part # 2337493 - Datsun 280Z 3/4" bore slave cylinder
DORMAN Part # CM39896 - Ranger 7/8" bore master cylinder (willing to modify the bracket and firewall)
This is the right stuff? Anything else I'm missing? Adapters, fittings, ect.
That looks like the combo you need :icon_thumby:
SVT
Ordered the two parts using the helpful 5% off coupon from Rock Auto. :icon_thumby:
