- Jul 31, 2021
- NW Florida
- 2.3 (4 Cylinder)
- Total Drop
- 1.5” till I get these springs replaced
- Tire Size
- 225-70-R14
This isn't for the ranger, but is a universal question. I'm trying wire a fan so it turns on and off with the compressor. There is no fuse downstream of the relay, so I have to tap into the relay signal (I don't want to splice into wires). I currently have a wire soldered to the power output of the ac clutch relay, but I just can't get it to seat fully into the socket. Is there such a thing as a relay with longer connectors or an add-a-relay thing? I think I used 16ga wire and will try something thinner, but if there's no clean way to do it I'll just wire a little jumper to each pin. any ideas?
