taking lift off
lumberjack
Ok have a 94 ranger ext cab with I think a 6 in lift w 35 and wanting to take off. Ithas blocks. In the back which I can do but not sure what all I need to take off the front I'm thinkin just the drop bracket and the coils and just put stock one in but I was wondering if I need to change radius arms or beams out. Just want it to sit stock now
if you have a drop plate lift, then you will be able to take the axle beam brackets off of them. otherwise, you will have to source a set of stock beam brackets.
if there are drops on the radius arms, you can just unbolt them and bolt the radius arm bracket back on.
if you have a drop pitman arm, you will need to bolt on a stock one
switch to stock coils and shocks as well
i think thats about it. as the others have said, pics will help
If you were in NY i would give you the stock ones for free if i could have the ones you got!! lol.
