RangerCamp
- Jan 31, 2008
- Automatic
Hi there, thanks in advance for any input.
Recently my 96 Ranger 4x4 supercab started making a clicking/popping noise when turning at slow speeds, like in a parking lot. Sounded like it was coming from the front left tire area. Then yesterday the steering wheel wouldn't easily return to center after it was turned. I went under and felt around, and the drivers side tie rod could easily be turned back and forth by hand.
So today I took it to Ford. Would have gone to an independent but I also wanted them to fix my No 4x4 Low Range issue. ($333 GEM, no guarantees it will fix -- no thanks for now). ANyhow they just called and said I need 2 u-upper ball joints, new front axle u-joints, new drivers side outer tie rod, and stabilizer link bushings. For a total of $1300.
Thing is, I had those u-joints and all 4 ball joints replaced 3 years ago (only 40k miles since) and the stab. bushings LAST summer. And the joints are the Moog greaseable kind. and I have kept them greased (tried to at least.)
Is the dealer trying to screw me? Could not-recently-greased aftermarket joints be considered "failed" to Ford? Might a shot of grease bring them back to life? Any other input? I can't keep putting $1300 of front end work into this thing every 2 years (had RABS done last summer too). Only has 90,000 miles. Thanks.
