Tachometer issues. 2.9
ty.forestcom
Forum Member
USA
I’ve got a 1988 2.9 xlt.
Newly swapped with a 5 speed. The tachometer has never worked but ~10% of the time. Nothing changed with the manual of course. I can do fine without it but would like to have it working 100% anyways. I have a suspicion it’s a ground issue and want to know if anyone has dealt with this before. Do I need to pull the cluster out to diagnose or is there an alternative?
I have the truck at about a 5” drop up front now and aligned it the best I could on my own, decided to get a professional alignment with some very old yet camber bushings I was able to track down on eBay. Was not easy 😣 . I have never paid someone to work on the truck before but since it will be there I was thinking of getting him to fix the tach as well. I’ve got a good bit of experience, rebuilt the A4LD while searching for my trans doner. Axle flipped, notched, beams, frame wire wheeled and coated. If y’all think I can fix the tach please let me know haha. I don’t mess with electrical much.
Thank you.
I think those tachs have 2 adjustment screws on the back, red to adjust the RPM and white to sensitivity.
Hmm… do you think it could be that simple? It isn’t inaccurate but doesn’t move at all 90% of the time. Maybe the white screw would get it working ha. I’ll give it a shot. Hopefully I can wiggle up there without having to pull the dash off.
Update. Negative on the adjustment screws. You may be thinking of a newer model sir. I’ve got a first gen
So sorry! I saw this video and thought it might apply to your problem.
There are metal clips that hold down the flexible circuit board on the back of the cluster and attach to studs on the back of the gages to connect them. They get loose and lose connection until you hit a bump or tap on the dash. You can remove them and bend them so they hold again
