Backcountry_Ranger
- Feb 15, 2008
1994
88 ranger, 2.9, 4x4, XLT, supercab, 270k miles, Sierra Nevada mountains, CA; 95% highway, 5% offroad, lots of snow (except this year)
The tachometer has started jumping around intermittently, up to +/- 1,000 rpm. Tends to happen on uphills, but not always; the tach behaves about 99% of the time. These fluctuations are rapid-- sort of like what you'd see with a failing speedometer cable. At first, it's just the tach needle, but if it continues, the engine begins to lose some power. At it's worst, I need to head back downhill, then all is fine.
Pulled codes (OBDI) KOEO: 67, 87, 95
KOER: none
The KOEO codes are: 67, switch stuff, like neutral switch, clutch switch, AC clutch
87: fuel pump relay
95: thermactor air system or fuel pump monitor
The relay, connector, and wiring were a corroded mess that needed changing out anyway. Done, no improvement.
I visually checked the switches and wiring, but didn't do continuity checks yet. I was particularly interested to see if the neutral switch was well-seated-- it was, and the wiring looked good.
Any ideas? Thanks.
KOER: none
87: fuel pump relay
Any ideas? Thanks.
