Tach needle for a gen 1
My cluster is custom. I kept the speedo that came with the truck. I rewired the plugs for a cluster with the tach. That is why I only need a needle but thanks for the offer.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Different JY
Sent from my SM-N910V using Tapatalk
Something to think about... a needle from another similar era Ford might also work for you. Go back to said JY, or "Different JY" and check out the other Fords in there. you might come up lucky.
AJ
You would think that the speedo needle would be the same but not.
Go out in the yard. Find a nice twig. Drill tiny hole at one end of twig. Glue twig onto speedo shaft. All of a sudden, you have the most unique speedo needle ever for 2 cents worth of glue.
Do you paint it orange to match the speedo?
Only if you're rich
Sent from my SM-G920V using Tapatalk
