T5 help need asap
dangerous_rangerous
Solid Axle Swap
I have a 94 mustang gt with the 5.0 in it and a T5 5 speed. Reverse got blown out by previous owner. Heres my question.... I have a T5 from a v8 camaro are the guts the same as the ford T5?
I think so, just make sure you swap all the parts unless you are sure the gear ratios are the same, or else it won't work.
Put them side to side and compare, I think the only difference is the bellhousing mounting holes.
