T-Bar Question..new kind
dmanmccann
foothills, NC
ok 2 questions..
1.) Over time your bars sag right? Well if they are cranked up, then eventually when they sag lower itll be right at where you started, well if you de-crank them want it be lower then factory afterwards??
2.) Exactly how FAST does cranking your bars, say 4-5 times, wear out stuff?? And what does it wear out...
And will it keep wearing out faster than normal wear and tear (after replacing the stuff the 1st time)?
That depends on how much you crank them. I lifted mine about 1.5" and then had a front end alignment. After about 70,000 miles that way I have not worn out anything yet. I did replace the tires but got a good 65,000 miles out of them and I doubt I would have gotten any more without cranking the T-bar.
Yeah i had an alignment also...well i cranked myn 5 on the left and 4 on the right,. The left has about 1/8 to 1/16 still sticking out and the right bolt has about 1/4 inch sticking out..So Technically its not maxed....I just dont want to have to replace my front joints every few thousand miles!!
