t-bar front end 2wd to 4wd
bigboy273
Grayson,GA
I was wondering what all i would need to do the swap from 2wd to 4wd on a truck with t-bar front end and if any one on here has done this advise would be greatly appreciated
-Cody
Its a bolt in....kinda...The two issues you need to get around is the transmission and the electrical wiring. The choices on the trans is to dissassemble it and install a 4wd output shaft or buy a 4wd trans. On the electricl side you can get around it buy getting a manual transfer case. If you want to use an electric transfer case you will need to change the wiring harness behind the dash and going to the transmission/transfer case and change the computer.
Parts:
Front axle(with matching gear ratio)
axle shafts
spindles(2wabs or 4wabs depending on what you have)
front driveshaft
rear driveshaft
transfer case
transmission
frame mount for the rear of the front differential(I made mine)
Good luck
John
