T-5? Worth it or not.
constant_projecttruck
London, Ontario CA
I find no better fealing then ramming through the gears of a 4 or 5 speed. So, with my 302 swap underway, is it worth it to to put in a T-5? The thing I am worried about is the technicality of setting up the clutch linkage, slave cylinder, going from hydraulic to mechanical in my Ranger...the list goes on. Should I maybe just drop the thing in set it up and let a pro set up the clutch. I am mechanically inclined enough to do the actual swap, but I know nothing nor have I ever done a clutch linkage job or anyhting. What are your thoughts?
