dave@threat
- Jul 4, 2008
- Automatic
When doing a T-5 swap to a 4.0 OHV do you just use a 4.0 clutch assembly and flywheel? Or is there something different I need to use? I picked up a T-5 with a T-4 bell housing and a Hurst short throw shifter for $400.00 the trans came out of an 88 V-8 mustang so I want to make sure I get all of the correct parts to make it work. Also do I need to get a different pedal assembly? Or can I modify a Ranger factory manual pedal assembly to work with a cable set up?
