n_bannerman
Im wanting to remove the sway bar on the front end of my 88 4x4 ranger. the thing holding me back is the sway bar mount on the radius arms share the same u-bolts that hold the lower shock mounts on. should I just go get some grade 8 nuts/bolts/lockwashers to replace the u-bolt when i pull the sway bar off or is there something better i can do for eliminating the bloody thing? by the way i did a search on this and looked through the tech library a few times trying to find out more info on removing the front sway bar.
