kevinsranger
did anyone notice a big difference in road manners when they took off their sway bar? i was thinking of taking mine off to get more suspension travel.
It will roll more. Try it and see how it feels to you. Something like that is a decision you should make yourself.
Nope. You only have to remove one link actually.
That would be better too so that the swap bar doesn try to start swinging around.
if u are gonna take the sway bar links out ,u should take the whole sway bar out.the sway bar adds stability and without it you will have allot more roll around the corners.if u go offroadng allot it is worth it but if u only go once and a while its not worth it imo
No, a sway bar works by not letting the 2 sides move in opposite directions, when you remove one link the the whole bar will travel with the side its still hooked to, the other side is not hooked to anything so it can't limit travel.but wouldnt the other link limit that side of the suspension?
