Sway Bar HELP
olskool kid
Oregon
I just got done putting in my 86' lowering kit into a 92' ranger. The tie rod end-outer and the adjusting sleeve rub the sway bar. Is there longer end link i can get?
lowering kit is DJM 3/4​
Check to see what exactly is rubbing. I had to rotate the bolts on the adjustment sleeve to clear mine. You can also flip the sway bar. I have an aftermarket bar and it actually cleared better then my stocker.
James
It was rubbing on the adjustment sleeve i just trun it over so the bolts wont rub..... As any one put a rear sway bar on there lower ranger?
Yep, got one of those too. You may need to cut down the end links that you get with a kit. I took mine off when I did the spring hangers and shackles last year and haven't put it back on yet. I am hoping to get some time for that in the next few weeks.
Any particular questions?
James
I am not sure on that. I would assume that any RBV would work on the Ranger.
I went with a hellwig bar. I really liked it on there and it came with everything I needed.
James
ok.... I will start looking for one and let yall know which one, I be getting. I may get front an rear done at the same time........Be getting a pic of the ranger sometime this weekend.
