Sway-bar drop brackets
shadow88
CLOQUET MN
Was thinking about a 4'' rough country lift, where can you get sway-bar drop brackets? The info under the description says I need them, just trying to put a list together so I know what this will cost me:yahoo:
I dont have sway bar drops on my truck. Worked just fine until i took it off completely.
And the rough country still uses the drop plate which will interfere with your dana 35.
They come with the kit. Put mine on a year ago. I have had no problem with the drop bracket. But i'm not very extreme.
Its basically stock. I built mine using a 1354 front drive shaft from an explorer. I can measure it when I get home
yeah, it comes with it.
if you use the RC coils, ditch the sway bar... I dd'ed mine with no sway bar till I put the EB coils on it. The RC coils are so stiff it doesn't matter.
OR you could make custom longer links with quick disconnects and keep the sway bar up where it goes.
