JoshErnst1074
- Feb 13, 2014
So I swapped an 89 2.3 to a 95 2.3. The guy said it would work. Turns out I had to swap all the pulleys and the power steering from the old motor over so the serpentine belt would fit right. Started the truck up, it purred. Ran perfect for about 3 hours. Then the brake booster check valve broke off so I had no brakes. Had to duct tape the vacuum hose back in to get home until I bought another check valve. Halfway home the engine started sputtering and lacked power. If I didn't keep on the throttle the truck would die while rolling. I replaced the check valve the next morning, thinking the brake booster was causing a vacuum leak I assumed the engine would run normal now. Not the case. It's backfiring, won't idle unless I keep on the gas, and sputters and jumps while driving jerking the truck around. I troubleshooted for around 8 hours yesterday, checking all the vacuum lines, ignition, fuel pressure, sprayed starter fluid all around the intake checking for leaks, made sure all the sensors were plugged in from the swap, I literally cannot figure out what it is. The only thing I can think of is the crank position sensor. Would be purely coincidental, but possible. What do you guys think?? Can't wrap my brain around this.
Also, forgot to mention my power steering doesn't work for some reason, and it idles perfect for 5 seconds, then starts sputtering and dying out.
