swap questions
krazyk
so I have a 92 ranger 2wd reg cab reg box with a m5od and a 93 explorer witha 4.0 and a a4ld 4x4.
anyway, I want to put the 4.0 and a4ld in the ranger
quesion1: can I remove the transfer case and use my exsisting driveshaft?
question 2: If not, can I run the t-case without the front drifeshaft?
any help is appreciated
Question 1: no
Question 2: yes
Question three: why???????
texas hills + 2.3+ clutch slave going bad = fail
I could use the 5 speed but I'm sick of driving manual. I do plan on slapping the biggest trans cooler I can find on it. Maybe even one of those 5" ac fans from a honda or something
no because a a4ld off of a 4.0 will not bolt to a 2.3
Slave cylinders are cheaper than even the least towing bill when the A4LD fails.
AD
yep, bigger motor is the whole goal here. just trying to make it work with what i got
