Suspension questions
98Mazda4X4
i plan on putting 3 inch blocks on the back and doing a t-bar crank on the front on my 98 mazda B3000. how big of a tire could i go and does anybody have any pics of a ranger or a mazda on a 3 inch lift.
i would say 31's or 32's but i would go with a 2 in block so your sure it sits level, you could always do that and add a 3in body lift for around $100 then you could definatly clear 33s or 34s or cheap coil spacers.....look on my profile for pics i have a 2in body and 3in suspension with 33's.
look in the tech fourms under lifting for cheap it has exactly what your looking for.
Does yours already have the factory 2 inch blocks? (that say pink and blue under them... never understood that)
I personally would never go bigger than a 2" block.
it came factory with 2 1/4 blocks on the rear axle and i was goin to go to a 3 inch block or a 4 inch block
So... it sits the same as other 98+ 4x4 rangers correct?
Crank the t-bars slightly, leave the rear and you can run 265/75/16 (if you have 16's) which are approximately 32's, and with higher offset wheels you can run 33's.
You will/need to be more concerned about your front suspension than the rear imo.
yea it sits the same as the rangers and i have 30's on it now but have room for more
