surprise in '94 a4ld pan
trikerider
'94
dropped the pan for a shift kit install and filter/fluid replace
behold a steel pin (it's magnetic) 1&5/16" length by a bit less than 1/8" diameter was laying in the pan. it has a high surface finish (centerless ground after heat treat maybe) and is convex shaped 'ball end' on each end.??
what is this? where does it fit? any help appreciated - I'm readyiing to drop the VB tomorrow morn.
I did use a 1/4"x1/2" self drill/tap screw to give a fluid change hole - it sealed right up, I used a viton gasketed sealing washer. I'm going to braze in a pipe bushing for a 1/8"npt plug for permanent but I believe this screw would hold from now on unless overtightened.
anyone hazard a guess? I dropped the VB just minutes back and no sign of a missing pin??
Alignment dowel of some sort maybe? Its been a while since I've had the pan off a Transmission so the image isn't fresh in my memory. Any pics of pin and valvebody? they would help alot. Centerless grind after a Heat treat would produce a low surface finish btw (example 2 rA as opposed to 50rA).
definitely not from the VB. I dropped it and a spring about 3/16" by 1&1/4" was also stuck in a channel of the case, easily popped out.
sorry digi-cam no worrky
going to acces Glacier's a4ld build thread hope to discover what is
mystery pin
it appears this is the pin from the modulator. the spring may well be also
