59Ranger92
In the morning when I leave for work the truck will run like it has no power. It will go through first gear and then doesn't seem to react to the throttle. After about 1 to 2 hundred yards or so it just wakes up. I don't have to give it any more throttle, it just seems to hit a power band or something. After that it runs fine. Could this be a throttle position sensor? And if so why does it only do it when the motor is cold? I mentioned that it does it in the morning but it also does it in the afternoon when I get off work. So it has something to do with the temperature. Any suggestions would be appreciated.
