Surging problem...TPS specs?
65Ford
Connecticut
Hi- Just wondering if anyone knows how I can test my throttle position sensor? Can I ohm it out? Just put tranny back in and didn't have this surging problem before this. I had to replace drivers side exhaust manifold gasket too and removed EGR valve to make room; would a bad EGR valve cause a surge? It seems to happen at either under heavier load like when in 4th-5th gear and going up a hill or from a stop and put it under a bit of a load. I'm thinking TPS because seems to happen when pedal is roughly same place when it happens. I can apply more gas and it will buck some but then go away. TIA-
