Superlift problems
memorex402
North Carolina
I went to install my lift today and ran into a issue. Based on following the instructions on order, you are supposed to drop the radius arms before you do anything else, to include removing shock absorbers and coils. I removed the rivots and bolts as the instructions say but the radius arms wont move either way more than an inch. Im sure Im just missing something stupid here, or Im not putting enough umph behind it. Any help would be appreciated. Thanks.
I'd pull the shocks & coils (and swaybar), then loosen the radius arm-to-axle bolts. The arms should then pull right out of their brackets.
Or pull the axle beam bolts also and then drop the whole axle as an assembly.
It turns out after I said screw the directions... The shocks were what were keeping it from dropping. Maybe I should look at the directions just by section, and not necessarily in order.
