Superlift extended radius arms install help
RobinHood
Henderson, NV
l have a set that l will be installing with my 5.5" Superlift. Unfortunately l picked them up used, so l have no instructions. l searched the Superlift website and the forums, but found nothing... l have a general idea but would like some info on the install.
Here are some of the questions that l have...
1) l have to grind the rivets on the old brackets off, then remove the old brackets and discard them. Then mount the new bracket using the cab mount (after removing the two rivets in the bracket) and drilling the two holes, correct?
2) Is it as simple as once the bracket is mounted remove the old ones and mount them in place of the old ones? IS there a best time to do this while in the middle of the lift? Is it best to do it first, in the middle, or the end ?
l appreciate the help in advance. If you have the link for instructions l will take that as well. Thanks again.
Should the existing crossmember that holds the OEM radius arms be removed or left in place once the extended radius arm brackets are installed?
Remove all of the stock radius arm parts including the cross member. The sole purpose of that cross member is to keep the stock radius arm brackets from buckling inward.
