Superlift 4" kit
FourPointOh
Americas High5
since this kit for the 2001-08 rangers 4x4 dosnt actually lift the frame any, it would leave the same gap between the bumper and hitch that a 3" body lift would correct?
its a torsion bar set up with blocks in the back, so if the frame isnt being raised, the hitch wouldnt move....overall i guess that answers the question i would think, just kind of a bummer
all suspension lifts move the frame higher. Is'nt that the point of a suspension lift to get more clearance between the frame and the ground.?
the 4 inch superlift is a SUSPENSION lift meaning it DOES move the frame....
so the hitch will be exactly the same as it is now.
the hitch is going up with a suspension lift
Yea but the distance between the bumper and the hitch will be the same.
But yes the hitch will be 4 more inches from the ground
but the kit says if you have front tow hooks, you will not be able to use them unless you remove your bumper valence, so this would mean the frame is remaining in place, correct?
a suspension lift raises everything except the axles. Your whole truck will be raised together. You are talking body lift stuff with gaps and not being able to use your tow hooks without modifications
It sounds to me like you are looking at a body lift? the susension lift should have nothing to do with your tow hooks.
