Waves
- Jan 27, 2014
- Houston, Texas
- Automatic
- My credo
- Just a Little Off
Guys -
I have been building a project for the last two years, I brought a 99' Ranger Extra Cab 4x back from the dead.
To date I have replaced the motor, transmission, transfer case, rebuilt the front end, swapped out the rear diff (7.5 for an 8.8) and re-geared both from 4.10's to 4.88's and added a detroit tru-track to the rear, I could keep going but that is the greatest hits.
So this is my issue, I am running a superchips FlashPaq tuner, and when using either the Torque or Performance program, they both perform perfect shifting first to second gear, but the second to third gear shift sometimes short shifts while at WOT, if you let off for a second and then go back to WOT it down shifts and then seems to throw the computer off and the transmission goes into neutral, you let off the throttle and right back in gear. It only does this when running those two programs, when I run the factory program, the truck does not do this. I can kind of drive around the issue but I would rather not. Let me be clear - this is ranger number 6 for me, I have built 5 others, my last one I had a SCT programmer with a custom written program from a guys named Doug who at one time worked for BAMMA Programmers, and if anyone knows how to contact him or anyone like him who really knows Rangers and how to program them - please send me their info, I am more than willing to scrap the Superchips one, call it a loss and go with a plan B.
The Superchips programmer boasted that I would be able to change tire size, grears, shift points - it does none of that for my truck. They think I have an oddball computer (possible still a 98) so I can only run what programs they have as they are. My speedo is actually correct something in my gear and tire size change is just right that my speedo is still dead on when checked with GPS, so while it's not an issue I would still would prefer my computer be getting the right info, as well as being able to try an adjust the shift points around the short shift issue (in other words it shifts early and leaves me in a bad rpm range when I am still trying to accelerate at WOT).
Has anyone else had this issue with a Superchips programmer? Any suggestions or any ideas? Sorry for the long post -
My trucks specs are as follows:
99' Ranger XLT Extra Cab 4x4
3.0 V6 w/Automatic Trans
5 inches of lift (3 Body and 2 Suspension)
4.88 gears running 265/75/16's
