stclist000
- Jan 14, 2011
- Automatic
I replaced my fuel injectors a month ago, one was bad had plastic broken on end. Anyway, I was trying to inprove my fuel milage was getting about 12-14 mpg city, now getting 7.5 mpg. Tank does not leak, many new parts , plugd/wires, fuel filter, air filter, different throttle body, my other one had bad o ring seals on linkage. different maf, and other parts. I got the injectors from a junk yard, same engine and they looked newer. But they were shorter than my old ones , one of the newer ones just keep leaking at the seal went through 4 o rings and decided to put one of the older larger ones on and it did'nt leak. Runs fine, idles fine, but my milage is cut in half. Am I going to have to replace the injectors again?
