Sun Tac. not working
The purple one
CT
1987
I just put a used tac. in my 93. Hooked up to the tan wire with the yellow line (I did this in the engine comp. not under the dash.) But it no work :dunno: Is there a way to test the tac. or am I doing somthing else wrong? One more thing I did not hook up the back light for the tac. Do not know if this would make any differance. Also I have a good ground and a good power supply.
what did you hook up the signal wire to? my sun has a green wire for the signal and a blue wire for the backlight.
the signal wire goes to the ignition coil ground
Is the ignition coil ground the tan with yellow strip? That is what I hooked the green wire too.
i've heard its the tan wire but im not sure. is this a 4 cylinder? if so hook it to the exhaust side coil
It is a 4cyl. What color wire on that side? Thanks
this is from our tech's: the link has been posted under your original post
For 1993 & 1994, Depending on the size of the motor, you can do the following:
2.3L - Off the PCM (powertrain control module) go to pin 4, which is a tan wire with a yellow stripe. Or, go to the ICM (ignition control module) and splice pin 12, which is a tan wire w/yellow stripe - this is the same for the 4.0L, too, except for the ICM connection, it will be pin 2 instead of 12.
