Broosedamoose
DaMoose is lose!
- Mar 10, 2012
- 4.0 V6
- Automatic
- Tire Size
- 31 x 10.5
- My credo
- Coming in second just makes you the first loser!
I have a 2007 Ranger XLT 4.0L, 4wd, 5R55E Auto, 195k. The truck has been fine! I went to pick someone up and suddenly it felt like it missed second and slipped. I let off the gas and then started again and it was fine. I drove about 2 miles, picked up the person and went to back out and had no reverse! It was like it was in neutral. I put it back in park and tried again. Nothing! This time I put it down in 1st and the truck moved forward so I put in reverse and it worked. I started down the road and it wouldn't shift out of 1st gear! I dropped it down to 1st again and right into 2nd and she shifted. Then into D and it shifted OK. About 2 seconds later the OD/OFF light began blinking. Now I have searched this site, FTE and just Googled "Flashing OD/OFF light" and I'm just confused about what is wrong. I checked the VSS, turned the truck on and off a bunch of times trying to see if the blinking light is flashing a code (it's not), used my code reader (Actron) and got nothing, even used my MongoosePro cable to deep scan and run a datalog but there are no flags, codes, or anything. I hate to bring it to a shop blind so I thought I would ask here first to see if anyone had any suggestions. Does it sound like a solenoid or maybe the valvebody? I don't know if the filter and fluid has ever been changed! (I've only had it a short time now) Any help is appreciated!
I noticed in my searches, not a lot of people came back to post what was wrong or how they fixed their issue so, I plan to do just that, and maybe help someone else with the same issue!
