first two much is all up to the user. i have ran everything from twin tens to a 15 in the back of a ranger. with both solid, and split glass no worries on breaking a window. thats from to much DB which your not creating, or the subs ratting two much and the movement physically breaks the window. not from a sound wave.
second, there is some bad info on this thread i aim to fix.
just dont hook them up and listen to see if its done wrong. and your gain is not is not is not, a volume control. the gain is a slope shit in the power curve.
ok now your amp and subs have a ratings three to be exact. your max power, your rms and your ohms.....first forget the max power.. its all bull shit and hype. to sell stuff. the two you need are your ohms and rms. these two ratings need to match. as close as you can. or you can break stuff.
your amp will have a "set rms" of watts at a given ohm, you need to find out what the ohms for your subs are then wire them correctly so that your amp and subs match.
so a question for the OP is what are the settings for your amp and speakers (both sets) and we can see were you stand on making a system.
