reginald fairfield
Hey ya'll I need to know what would cause the blinker in my 99 to not work. When I first push the blinker on, it just blinks right once or twice and then just stays on continuously instead of blinking. Ideas?
Low blinker fluid. Or perhaps the blinker piston has gone bad.
Burned out bulb or the flasher is bad.
Before going after ANYTHING else, make sure all the bulbs work.
Almost all the time, a dead or nearly dead bulb is what causes steady blinker problems.
There is only one flasher unit on RBVs, so ANYTHING flashes (both turn signals and the 4-way flasher), the flasher unit is just fine.
if wiggling the multifunction switch can make it work, remove it and lubricate the inside with a chemical like deoxit. the contacts are prone to having issues. also try to turn the 4 ways on and off some times that can fix erratic sw issues
