samx227
Alright so here's the story.. 1990 ford ranger 4.0l v6..start off with what I did.. M5OD swap, used ecm out of 90 mazda navajo (5 spd, 4x4, 4.0l) truck ran great after swap been drivin it for almost 2 mos now. Truck took a swim in the river up to the headlights and cab filled up w water. Pulled it out and did normal procedure (pulled spark plugs, cranked motor over and it spit out the water, cleaned intake area and replaced air filter. All was well and the truck ran great for about 3 more weeks. Decided I'd take it on a 70 mile trip out and do some camping. Ran great on the hwy. Found some clay puddles out on some trails and went through em but they were mostly just water. Truck still ran fine. Fired it up next day to go to the general store and noticed when I turned onto the hwy it missed a little..weird. kept driving, stopped at the store, came out fired up and started drivin. Hit 3rd gear and engine missed/bogged again. Weird. Kept driving and about halfway to camp it bogged out and wouldn't go anywhere. No cel, would just turn over and over and over. Thought it was the fuel pump. Jumped the relay and you can hear the feul pump turn on. Checked up front and could smell feul, pushed in the schrader valve on the fuel rail and it squirted fuel. Replaced relay. Still no fuel pump on ignition. Checked spark, just cus. And we have spark. Noticed that when truck is put into accessory the cel doesn't come on for the quick second that it usually does.. tried to pull codes..no signal and no flashy cel. Started to thinkk it was the ecm so I swapped in the auto ecu to see if it would fire up. No start and still no cel. I am stuck anyone have any idea what to check next? Thanks.
