93rangerstx
I can't get my ranger to run. The problem started on my way to work the other day, the check engine light came on and the truck lost power. It began running rough, spitting and sputtering, and I limped it to work. After work it wouldn't start. Then after hours of unplugging and plugging back sensors it fired up running rough and engine light still on, got it home and it won't start up. Turns over but will not fire. I've hooked up 2 different code scanners and neither one will respond. I just changed plugs and wires about a month ago and everything else seems to be working fine as far as fuel and what not. It was running rich when it was running. I'm lost, I would appreciate any help, thanks.
