justinae
Hi all. First time Mazda/Ford Ranger owner and first post here on the thread. I'm a general contractor in Portland and retired my 1980 Datsun 720 as a work vehicle and upgraded to the B4000. So far really happy with it, except gas mileage stinks.
Anyway, I've spent way too much time trying to figure out how to wire up my trailer. Specifically the towing vehicle side. I tapped the wires as follows:
Yellow harness wire --> Light green/orange stripe on the left
Green harness wire --> Orange w/ light blue strip on the right
Brown harness wire --> I tapped into each of the brown wires going to the brake light on both sides and joined them into one wire which goes to the harness
White --> Grounded to frame
With this setup, everything works fine on the truck, but nothing on the trailer. Originally I set it up with tapping the brown into the black wire that also went into the turn signal on each side. So again, a brown coming from each side, joined, then harnessed. When it was setup like this the turn signals worked fine but no brakes on the trailer.
Attached are a couple pics. The previous owner had a front mount towing harness setup.
Seems the problem is with the brown but I've tried a lot of combinations. I tried connecting to all three colors coming into the brake light and that just shorted the fuse.
You can see from the first pic that there is a lot going on. There is a canopy that has a brake light, which also taps into the brown coming from the truck brake.
Any help appreciated.
Justin
Justin
