1990DangerRanger4X4
- Apr 17, 2014
1990 Ford Ranger 2.3L. As I said in my earlier post, I have spark but no fuel. I have replaced the fuel injection relay, ignition relay, and the ICM module. I located the ECM in the passanger side kick panel and replaced both the grounds for it. I am worried the ECM itself is bad because of corrosion caused by moisture from a hole in the floor board. As you can see in the attached pictures, it looks pretty corroded. I removed the fuel injector wiring harness to make sure all the wires are fine, which they are. The only other 2 things I can think of to replace which I havent already are the crankshaft position sensor and the idle air control valve (IAC) but if the IAC was bad it should start just not run right. If anyone can give me some guidance I would greatly appreciate it. I only have another month to fix it as I am PCS'ing back to the states from over seas.
