ekrampitzjr
- May 28, 2021
- Virginia
- 4.0 V6
- Automatic
Hi, new member, posted an introduction in the intro forum. Have a question about a weird thing.
2011 XLT Supercab 4-door, 4.0 V-6, 2WD
An electrical noise appears with the truck running or off. It sounds like a fan grinding or a worn-out buzzer. It's coming from around the instrument panel. It does not seem to be the well known blend door actuator problem, which is behind the glove box.
It showed up for me just after a tire shop followed the directions to reset and turn off the tire pressure warning light after replacing two sensors (both rear wheels, the fronts had been done before I got the truck).
I discovered that the turn signal switch or hazard flasher switch would stop the noise, even without the key in the ignition. Playing with the key in the ignition sometimes stops the noise. Hitting the turn signal switch as if making a turn is what I mean. Doing this when the ignition is off also shuts down the anti-theft flasing light in the display. The anti-theft light does not start flashing again even if the switch is turned back off.
The noise is sporadic. It goes away and then a few days later reappears.
All gauges, other warning lights, switches, A/C + heat, turn signals, power windows and locks, remote key fobs, and audio system all seem to work properly.
When I get the truck back from Line-X, I will check the cab ground connection, which I understand is under a panel beside the emergency brake. That was true for slightly older Rangers; still true for 2011? The truck is in excellent shape, but you never know about corrosion.
Any thoughts about the cause of this? Thanks!
