I changed my brakes about three weeks ago and ever since I have been hearing and feeling this noise that sounds like metal on metal. It does not pull or effect my stopping in any way. At normal driving speeds there is no noise and even when I first apply my brakes there is no noise but the last couple feet of con my to a full stop there's a metal on metal noise coming from the drivers tire.
I have totally taken apart my brakes and rotors three times to try to find the issue and each time it will go away for a couple days and then come back. The first time I took apart the brakes after the change I thought I hadn't tightened down the spindle nut enough so I torques it down more and noise went away for a few days and came back. Then last week I took everything off regressed all the bearings and bearing surfaces inside rotor and again it went away and came back.
The passenger side makes no noise whatsoever and I did everything the same with the drivers side as I did the passengers, could I have gotten a bad inner wheel bearing when I bought my parts? I am completely clueless after tearing into it three times with no fix.Anything helps.
