CAminitruck
- Jan 9, 2009
- Automatic
Hey folks - any help is appreciated!!
A buddy gave me his 93 Ranger, 3.0 V6/ AT because he couldn't fix it himself. He cracked the radiator and went on to blow the HG (between cylinders, luckily, not between oil/coolant passages). I replaced the radiator, checked the heads and replaced the head gaskets. Also replaced all the spark plugs, spark plug wires, cap and rotor.
Engine was running rough, so I did a cylinder balance test and it pointed to #1 and #5. Compression checked out OK. Emissions check pointed to a lean miss. I replaced the injector on #5 - no improvement (injector is a reman unit, but 'new' and with a good warranty). I went out to run the compression test again, and forgot to disable the spark system. Engine started during the test on #5, and I noticed an intermittent knocking sound (even after the spark plug was put back in cyl 5 and the engine was running 'normally').
The engine is also periodically backfiring/stumbling. Seems smooth at higher RPM, but at idle is when the problem is most noticable.
Anyone have any ideas? I'm starting to go slightly batty...
