marriedmanw
The other day while getting firewood I noticed my battery needle dropped down to 8V and the battery light was on the dash. I went to the auto parts store and they checked battery then said the alternator was bad.
I drove truck home and took battery out and measured at 9V, so I put on slow charge for 2 days then tested at 12.9V. I put the battery back in the truck and it started up, then I measured voltage coming back into battery and it was 14.34V which tells me the alternator is working. I checked my serp belt for tension and it was tight so I know it is not slipping. I did unplug the electrical connections at the alternator, cleaned and reconnected before putting battery back in.
I will be driving it tomorrow for 50 mile round trip so I can monitor. What else could I check for? The starter is new and not drawing much juice at startup. A older guy I know told me to start truck and while idling take the positive battery cable off. He said if it stalls then the alternator is bad. Is that safe to try?
Truck is 92 F150 Custom with 4.9L I6 with 233K miles.
