stock susp swap questions
Nailzs
salisbury, md. east of cheasapeake bay
88 ranger 2.9 5spd 4x4 vs 88 b2 2.9 a4ld
are the front springs the same?
whats the easiest(quickest?) way to swap out the d28 diff?
story goes that when i got the ranger i swapped the d28 and 7.5 from the bronco to the ranger. for the d28, i swapped over everything, springs, ttb's, radius arms, etc(yeah, that was stupid). now i gotta swap everything back as the ranger has a bent frame and a bent right side radius arm. im hopin the springs are the same so can just swap the diff's over and leave the ttb's where they are at, and not have to swap over that radius arm also.
also, during the rebuild of the front end on the b2, would u guys replace the ball joints with regular joints or adjustable joints? same question applies to the radius arm bushings
