tlane3546
- Dec 13, 2008
Just thought that this should be put in the tech section.
For the 2.3L engines
Some certain year Rangers ( I believe 93+) come with stock tubular headers. This is a cheap little upgrade from a junk yard. Mine cost 20 bucks. Only thing is the EGR is a PITA to put back together, this if you disconnect it in one piece. i just sealed mine off at the header and the EGR valve and did away with the EGR system all together. The header will bolt up perfectly with the stock bolt. However if you can get all the exhaust bolts out of the donor truck i would keep them as it is very easy to break your exhaust studs off. Also be careful to no break off the stud that bolt the manifold flange and exhaust tube together. They are a pain to drill out.
NOTE: If you go to a junk yard where you pull your own part do not tell them its a header, say exhaust manifold when referring to it. Sometimes they wont know any better because they look it up in a book or computer that has common prices for parts, i.e; all ford manifolds are $20 or all ford headers are $75 dollars
