Lifted2x
Well I have been working on my truck but I still having problems running when its war. It starts up fine when its cold and runs good for 10-15 minutes then if you slow down to idle it will die then it wont start back up.
I was having problems even getting it to run for more than a few minutes and I found the wires to the O2 sensor were melted to the exhaust. I have rewired them and it helped alot but its still giving me problems. I have changed the MAP sensor, IAT sensor, TFI module, and fixed the O2 sensor, I know it has spark when it wont start and there is pressure on the fuel rail. There isnt any fuel leaking from the FPR and it looks like it has been recently replaced. Any Ideas. I will pull codes again but last time I did all i got got was the IAT code.
